Crawlspace paneling
Received 0 Votes
Crawlspace paneling
I own a cabin in Maine and it looks like this.
Imgur
I would like to do something to protect the paneling on the crawlspace. Some of it shows some water damage. Like this.
Imgur
Imgur
I'm thinking of painting it with an oil-based paint. Is there something I should do before that?
I'm also considering doing some sort of stone facing. Can I do that myself?
Thanks
Imgur
Imgur
Imgur
Thanks
Welcome to the forums!
Paint won't help the plywood where it's already delaminating
Oil base paint does offer more moisture protection than latex normally does. The would should have a primer applied before any finish paint. I'd be replacing the damaged plywood!
Not sure what type of stone work you have in mind but might be something you can diy ..... but you can't just attach it to the plywood.
Received 0 Votes
How do I replace the plywood?
The stone facing is like this.
How to Install Stone Facing | The Family Handyman
You'd cut and pry as needed to remove the damaged plywood.
Not my area of expertise but you need a masonry backer to attach the stone to. As Joe said, ideally you'd never have plywood in contact with the ground! it should be replaced with block or a poured concrete foundation - you could then install the stone.
