Vertically installed shiplap vinyl siding
Old 06-10-15, 07:05 AM
Geochurchi's Avatar
Temporarily Suspended
Received 89 Votes on 84 Posts
Hi All, looking to install fixture boxes as well as receptacle boxes on vertical vinyl siding do you use the same boxes as for regular vinyl siding?
Maybe I am making to much about this but I have never worked with vertical siding.
Thanks
Old 06-10-15, 11:32 AM
XSleeper's Avatar
Received 855 Votes on 783 Posts
Yes, you use the same type of mount. While you have it apart, make sure there is housewrap on the wall and if there isn't, at least install a vertical piece of WRB behind your new fixture mount so that when it rains, the water that leaks in will be on top of the WRB until it reaches the bottom of the wall.
