Exterior wood panel repair
Old 07-05-15, 11:04 PM
The exterior wood panels of our bay window needs some work. It has some nails I want to pull out and then fill the holes. The surface also appears to be cracking (looks like crazing that happens to glazed ceramic pieces), but since I don't think the paint would crack like this, I'm assuming some sort of filler has been applied in the past and this is what is cracking, but I could be wrong. I got up and looked at it, can't really be sure...So how would I handle these nail holes and cracks? Can I just apply a coat or two of wood filler type material over the cracking, or would it just recrack? Do I need to dig/break out this previous filler and refill it from scratch? I guess the absolute best way would be to replace the boards, but I want to try to avoid that - I think the panels are in decent shape except for this.
Anyway, all opinions will be appreciated!
Old 07-06-15, 04:13 AM
Received 25 Votes on 21 Posts
Pull the nail and use a dab of latex caulking, done.
Sand the other area until it's smooth, prime and paint two coats.
(Unless it turns out to be rotten wood causing it)
Old 07-06-15, 04:39 AM
Received 120 Votes on 107 Posts
I wonder if someone smeared caulking over the area in an attempt at a repair and either applied it too thick or painted it while the caulk was still wet. I'd sand as Joe suggested and see how it goes. While it could be filled, that should be the last resort. Makes me wonder why it was repaired to start with.
btw - welcome to the forums jd!
Old 07-06-15, 11:13 AM
First, thanks for the welcome. Frequent browser, first-time poster.
OK, yeah, I guess I'll start with sanding and see what happens. I just don't know what is going on there. I hope it's not that the wood is rotted out and somebody tried to fill it in, but I'm halfway expecting that...
Separate question - see where the boards meet the bricks? Any recommendations on type/brand of caulk for sealing there? It looks kinda sloppily done, and I might want to redo it sometime soon.
Old 07-06-15, 01:39 PM
XSleeper's Avatar
Received 195 Votes on 181 Posts
It looks to me like they used a piece of Masonite lap siding for the trim, I've seen it do the alligator cracking like that... cut end sucks up water and the paint lets go. Could also be MDO (an "overlay"... a coated form of plywood) ... hard to tell from just a picture. Since you already know replacement is the best option, I have nothing to add... just that the material used is probably the reason it's doing it in the first place and that it will probably only get worse.
Paint and putty might "help" but I bet you will be back at it again soon.
Old 07-08-15, 08:44 PM
Just wanted to say thanks XSleeper for adding your opinion. Appreciate the info from everybody!
