Go Back  DoItYourself.com Community Forums > Exterior Improvement Center > Exterior Paneling and All Exterior Sidings
Reload this Page >
Panel between 2 windows on bay window feel off -what do i need to replace?
Old 01-22-16, 09:44 AM
K
Hi
this is my first post. the panel in between 2 windows on my bay fell off. I need to replace it.
I spoke to some friends and did research online. it seems i need a flashing or a cellular pvc. i am not really sure. thing is when i look online to purchase on they are all flat. since i have a bay window there is an angle between the 2 windows.
Can you please help me with the name of the piece i need or where to get it or what i can use.
I included a image of the part of the bay window i am missing.
Thank You
Old 01-22-16, 09:54 AM
C
Received 134 Upvotes on 110 Posts
This is on the outside, right? A picture would help us identify the type of trim needed.
http://www.doityourself.com/forum/el...-pictures.html
Old 01-22-16, 11:16 AM
K
yes it is on the side. i did insert an image. did it not show up?
Old 01-22-16, 11:26 AM
C
The image showed up, but an actual picture showing where the piece is missing would be more helpful.
Old 01-22-16, 11:58 AM
Received 126 Upvotes on 111 Posts
We need a real picture of what you have, not a pasted drawing.
Old 01-22-16, 01:29 PM
K
is this image a good inage?
Last edited by ray2047; 01-22-16 at 01:49 PM. Reason: Rotate image to correct orientation.
Old 01-22-16, 01:50 PM
ray2047's Avatar
Do you have the piece that broke off?
Old 01-22-16, 02:39 PM
Received 785 Upvotes on 688 Posts
Do you know who manufactured the window? There is often a label in the corner of the window.
Old 01-22-16, 03:48 PM
Just not going to find that item in any store or on line.
OEM only.
First time in over 50 years I've seen one of them fail like that.
Something had to have hit that or a poor framing job caused it to start failing.
Not seeing any support under that window in that picture to stop it from sagging.
Back up and take another picture please so we can see the whole thing.
Old 01-22-16, 04:32 PM
XSleeper's Avatar
Received 1,808 Upvotes on 1,626 Posts
That piece is available fron Andersen. Color = terratone.
Old 01-22-16, 07:38 PM
XSleeper's Avatar
Trim strips... See page 152: http://www.doorswindowshardware.com/...1-narrolin.pdf
Yours looks to be a 30° bay. Contact Andersen directly through their website. Put the new one on with a little silicone.
