attaching vent to soffit
Old 02-10-16, 05:19 PM
I am attaching a plastic bathroom exhaust fan vent (like a dryer vent) to an aluminum soffit.
Should I use long enough screws to go thru aluminum soffit panel and into the old wood soffit above or would just using small sheet metal screws to attach it to the aluminum only be sufficient?
I prefer to do the later but what is the best method?
p.s. if it makes a difference the vent is attached to the duct with tape and a clamp.
Old 02-11-16, 05:16 AM
Received 126 Upvotes on 111 Posts
Should not be running it out the soffit at all.
Side wall or roof only.
Doing it your way the hot moist air can get sucked back into the attic and take out the sheathing on the roof.
https://www.google.com/search?q=soff...cIILu69d18M%3A
Old 02-11-16, 10:58 AM
Question still stands..... despite the previous posters assumptions.
Old 02-11-16, 11:02 AM
B
Received 47 Upvotes on 43 Posts
Not the best one to answer, but al soffits are rather stiff if i remember and should be able to support that with no problem. Worst case they let go and you then run a longer screw up into the wood.
Bud
Old 02-11-16, 02:37 PM
XSleeper's Avatar
Received 1,812 Upvotes on 1,629 Posts
The problem with only screwing into the aluminum is in the event anyone ever pushes down on the metal collar of the vent... it would rip the piece of aluminum soffit down. But I suppose if its inside a soffit its not like anyone is going to step on it.
Old 02-11-16, 02:47 PM
Not assuptions, well know facts and the proof is in all those pictures.
Hot air rises, well known fact for century's.
Old 02-11-16, 02:58 PM
XSleeper's Avatar
The assumption is that with no pictures, we don't even know if he has any soffit venting nearby.
Old 02-19-16, 08:37 PM
BridgeMan45's Avatar
Received 1 Upvote on 1 Post
But even though he's unwilling to show us (or explain in any detail) what his soffits consist of, he wants answers--NOW!
Sorry, but I think I'll pass.
As an aside, those are some great pix, Joe. They remind me of the book I've always wanted to write--"How Not To Do Home Repairs."
