Cedar shake siding
Old 09-06-16, 03:50 AM
Cedar shake siding
I am fixing up a 110 year old house that has cedar shake siding which I am going to have repainted. I am replacing many of the old shake panels that are damaged but don't know what to do with the corners, which have opened upon a couple of them. It seems like just remaining them would not work without some kind of cap. They are 5 inch exposure. I have seen the cedar caps which I could install on top via a cedar valley type company but they are very expensive. Any help would be greatly appreciated!
Old 09-06-16, 04:07 AM
Received 742 Upvotes on 648 Posts
Would installing corner boards [1xs] look out of place? pics would help us better understand what you are dealing with.
Old 09-06-16, 04:21 AM
V
Received 2 Upvotes on 2 Posts
I wonder if you could consider placing a few facia boards in the corners to terminate the shakes evenly, by creating a "corner post". It doesn't have to be very elaborate; but would solve your problem.
I mention it because I'm currently re-painting an 1832 house with cedar clapboard and we just solicited input on the color of paint(s) to use on our Corner Posts or Pillars in another Forum:
Seeking Opinions on House Corner Posts - Paint Treatment - Realtors Marketing Tips, Talk, Webmasters Forum
You might goggle "house corner posts" for ideas along that line.
Old 09-06-16, 05:01 AM
Tolyn Ironhand's Avatar
Received 676 Upvotes on 573 Posts
Put a 2x6 cedar on the front corner, overhanging by 1.5". The butt a 2x4 cedar to the 2x6 to finish the corner. This is similar to Mark's suggestion but a 1x might not be thick enough to the cedar shakes thickness.
Old 09-06-16, 05:07 AM
Actually I was suggesting nailing up the 1xs over top of the shingles .... I've painted a lot of houses done that way.
Old 09-06-16, 06:23 AM
So here are the corners that I am talking about...I actually framed out a screened in porch and used Cedar Valley 8 foot cedar shake siding to try and match the house (relatively close) after its painted. For those corners, I bought the Cedar Valley corner pieces (photos attached) and that works great (and easy to put up) but they cost $10 per linear foot. What do you mean by 1xs? I cant do one long piece up the corner.Name:  IMG_3563.jpg
Size:  52.9 KBName:  IMG_3564.jpg
Size:  50.1 KBName:  IMG_3576.jpg
Old 09-06-16, 06:27 AM
Tolyn: So essentially you are suggesting to create the same thing that I bought from Cedar Valley but to make it myself? And just caulk and pin nail it up? Or would I need to use an adhesive also?
Old 09-06-16, 06:31 AM
Vermont:
I don't think I want to get into cutting all of them to get the corner posts in. It is a 3 story house and all of the corners don't need the help, only the most weathered ones.
Marksr:
Just cut some cedar into 1 inch strips x 6 (to account for overhang)? Would pin nailing/caulk suffice? Or were you suggesting a different wood?
Old 09-06-16, 07:47 AM
Received 1,190 Upvotes on 1,147 Posts
Wow. Is it all in such bad shape?
Old 09-06-16, 08:03 AM
I'd probably use a 1x4, you can either prenail them together and install them as one unit [like your prebuilt corner pieces] or install one side at a time. A pin nailer might be ok for nailing the ends together but you'd need a common galvanized nail to attach it to the house.
You can use most any type of wood you want although cedar will last longer than pine.
Old 09-06-16, 08:29 AM
Most of it is actually in good shape for its age. The rough looking stuff was under a poorly drained flower box for years and needs to be replaced. I think I will cut down cedar and install the two sides directly to the corners. Thanks everybody!
Old 09-06-16, 08:32 AM
Thank you, I feel better knowing it's being replaced.
