1/4" paneling question
Old 10-22-16, 10:54 AM
B
Hi Folks,
I'm not so handy and I can't seem to wrap my head around this one.
Here's my situation.
I need to have a piece of 1/4 inch 8ftx4ft paneling cut into 3 pieces. 2@ 8'x 12" and 1@ 62" 3/4. Can I do this with one piece?
Thank you in advance.
Old 10-22-16, 10:59 AM
Received 1,177 Votes on 1,091 Posts
Welcome to the forums.
The 2 pieces of 1'x8' (12"x96") is half the sheet..... leaving 2' x 8' (24"x96").
What is the 62-3/4" piece by ?
62-3/4"x??
Old 10-22-16, 11:21 AM
B
sorry..twenty four and three qrtrs.
Old 10-22-16, 11:31 AM
The piece you end up with after the first two cuts is 24" x 96".
That means it is a sight bit too narrow to get a 24-3/4" x 62-3/4" out of it.
Old 10-22-16, 11:39 AM
B
Thank you. how much am I going to be short
Old 10-22-16, 01:53 PM
Gunguy45's Avatar
Super Moderator
Received 3 Votes on 3 Posts
You have to account for the width of the saw blade and lost wood when you make your first 2 cuts. A lot will depend on the blade used. Some may only be 1/16" wide kerf some may be as big as 1/8". Let's say you cut a total of 24 1/4" inch off and have your 2 long strips. That leaves a max width of your final shorter strip at 23 3/4" (assuming the paneling is exactly 48" wide).
Old 10-22-16, 04:43 PM
Handyone's Avatar
You will be 3/4" to 7/8" short on your last cut.
Buy your 1/4" material at a lumber yard or hardwood store (I think Lowes has it also), get melamine or MDF.
Melamine panels are referred to as 4 x 8 but measure 49 x 97.
