What should I use to cover this?
Old 10-24-16, 06:53 PM
B
I just removed all of my old Masonite siding and I'm installing Hardie planks. As you can see from the photo, there is a concrete foundation material with embedded wire mesh. Previous owners had foam board, flashing, etc. in this area. I'd like to try something different that would not absorb water and would look nice. This is on an older home. I'd like to cover this concrete material (below the flashing) with something that will last. If you have any suggestions, I would greatly appreciate it.
Thank you!
Jack
Old 10-25-16, 04:01 AM
Received 384 Votes on 340 Posts
Welcome to the forums!
Looks like stucco that is in poor shape, I'd remove any loose and restucco. It can be left unpainted although if you prime/paint the stucco it is less likely to absorb moisture.
What is that on the right in the bottom pic?
Old 10-25-16, 06:30 AM
P
Received 792 Votes on 729 Posts
I'd remove any foam or masonite up to your nailing edge. Then pressure wash the exposed concrete and paint it. There are some highly textured paints specifically intended for painting foundations that can help hide imperfections.
