Removing something screwed to Hardie siding
Old 11-08-16, 06:59 PM
R
Received 1 Upvote on 1 Post
My house has Hardie siding, and I have one of those crappy plastic hose reels screwed into it.
Once I remove it, what should I do? A little silicone caulk in the screw holes?
Old 11-08-16, 07:11 PM
XSleeper's Avatar
Received 1,714 Upvotes on 1,538 Posts
The best thing to use would be a color matched tube of OSI Quad. Otherwise use any printable caulk that meets ASTM-C920. Plain silicone is not paintable. It needs to be primed with a pigmented shellac before it can be painted.
Old 11-09-16, 02:49 AM
Received 741 Upvotes on 647 Posts
Do not use silicone caulk! As stated above it isn't paintable and even priming it with pigmented shellac can be problematic. If the Hardie is painted I'd use a siliconized acrylic latex caulk [it's paintable] or try and color match the caulk if the Hardie is prefinished. You could also use a clear latex caulk.
Old 11-09-16, 11:18 AM
R
OK, thanks! It's two holes, so the color match Quad may be overkill (the Hardie was prefinished), although the holes definitely will be visible. I will get some clear latex for now. My primary concern is protection, not cosmetic.
