Caulking exterior A/C lines
Old 01-08-17, 05:12 PM
What would be the best Caulk to use wear the lines go through the
Vinyl Siding into house. Thanks
Old 01-08-17, 06:08 PM
Gunguy45's Avatar
Super Moderator
Received 3 Votes on 3 Posts
You don't use caulk...you use what we used to call in the Navy "monkey s##t". You can find similar if you look for "plug duct seal". It's used to seal openings around conduit, gaps, and holes.
It's in the electrical section of home centers.
Old 01-08-17, 07:16 PM
Received 83 Votes on 78 Posts
Little late now but there should have been a siding block added where the lines came out.
I agree with how to do it just not with the terms on what it's called.
What you need comes in a plastic container like plumbers putty come in.
Old 01-09-17, 12:46 AM
Gunguy45's Avatar
Super Moderator
And some people say just spray foam it, trim it up and paint it. Critters love spray foam all by itself. Makes a nice warm cubby.
You could use foam as a backer in the wall (not too much, it can bulge the siding) then use whatever putty you'd like or can find.
Old 01-09-17, 04:02 AM
Received 361 Votes on 318 Posts
If you use spray foam be careful!! It's easy to make a mess with that stuff and it's difficult to clean off the siding!
Old 02-12-17, 02:44 PM
is this basically, the same product? the one that comes in the plastic container? thinks
Old 02-12-17, 03:17 PM
ray2047's Avatar
Received 13 Votes on 11 Posts
That should work. What Vic was referring to was Electrical Insulation Putty. It resembles a child's modeling clay and is black.
https://bh-estore.com/nitto-insulation-putty-500gm.html
Old 02-12-17, 04:32 PM
What a butcher job they did on that install.
Should have been a siding block installed.
Old 02-12-17, 04:55 PM
chandler's Avatar
Received 6 Votes on 6 Posts
I've not seen the other products, but this is available locally for me Gardner Bender 1 lb. Plug Duct Seal Compound-DS-110 - The Home Depot
