Issue with filling in nail holes
Old 04-09-17, 12:03 AM
D
Hi Guys - I have had a frustrating problem with filling nail holes in weatherboards/sidings. The weatherboards/siding are new and I filled each nail hole with the following filler:
https://www.bunnings.co.nz/polyfilla...450g_p00246716
After sanding back the surface, the filled in section has tiny holes in it and also stands out after painting. I have attached a photo to help demonstrate the problem.
Any idea what might be causing this? Filled around 40 holes and it's occurred to around 15 of them. Others are fine. Thanks in advance.
Old 04-09-17, 03:15 AM
Received 835 Upvotes on 732 Posts
Welcome to the forums!
Doesn't look that bad to me - I've seen a lot worse I'd just smear a little caulk over the offending areas and paint. Might not look bad with just a full coat of paint.
Old 04-09-17, 03:24 AM
D
Ha! Maybe I'm to much of a perfectionist. Thank you.
Old 04-09-17, 03:42 AM
chandler's Avatar
Received 9 Upvotes on 8 Posts
Stand back at the street and see if you can locate any of the nails.
Old 04-09-17, 04:13 AM
A
Received 73 Upvotes on 66 Posts
It looks perfect from here. Call it character, or whatever you want, but, regardless, I prefer it to the alternatives, vinyl, aluminum, or whatever. Not saying they are bad, but you've got something that a lot of homeowners don't. Yes, it requires more maintenance, and yes, you are going to see nail heads, but you're going to like it. As mentioned, step back a bit, and take in as a whole. Don't concentrate on small areas.
