how to repair small hole in siding?
Old 03-26-17, 11:55 PM
We recently removed a Comcast cable that went through an exterior wall and I want to fix the hole but don't know the best way to do so. I think the siding is composite wood. The electrician put some white stuff in the hole and I'm not sure what it is. I'd like to post a picture but I don't see an attachment feature here. How do I prevent moisture from getting in?
Old 03-27-17, 12:08 AM
Received 3,422 Upvotes on 3,068 Posts
Welcome to the forums.
This will help.... http://www.doityourself.com/forum/el...-pictures.html
Normally a little silicone or even electricians duct seal putty is used in the hole.
If you want to repair it completely..... use a product like plastic wood or Durhams rock hard water putty. Both dry rock hard. You could sand it smooth and paint to match.
Old 03-27-17, 12:45 AM
Here is a photo. Thanks, PJmax!
Old 03-27-17, 12:49 AM
another photo for scale (sideways)
Old 03-27-17, 03:41 AM
Received 741 Upvotes on 647 Posts
He probably used caulking, hopefully it's the paintable kind. Usually just touching it up with paint is satisfactory for most folks.
