Need help with outside window
Received 0 Votes
I replaced bathroom window with smaller one years ago. I am trying to find easiest and cheapest way to fix the outside of the window to fill in the gaps to make it look better. Here is pic of what I'm dealing with https://*******/cjXkov
Welcome to the forums!
Maybe inlay a piece of T-111 siding or something to highlight the difference. Be hard to camouflage it without removing the brick and redoing the siding.
First thought would be to install a larger window but must have been a really good reason to put something that small in.
Id look at the vinyl cedar shake siding, you could add a "J" channel around the existing channel and fill it in.
Noting is really going to do a good job of discussing that spot short of replacing the vinyl on the entire wall.
