vinyl siding around wood walk out
Old 08-05-17, 05:00 AM
G
I am remodeling the back of my house and I built a step with railing on either side coming off of the house and I don't know how to tie the vinyl around it as there is a corner very close to the door.
Imgur: The most awesome images on the Internet
How do I make this corner work with a railing that I have to make?
Old 08-05-17, 06:58 AM
Received 77 Votes on 72 Posts
Is this deck covered with a roof over it?
Reason I ask is if there's no roof, that decking is way too close to the wall and the threshold.
There's a couple of different ways to do it, the simplest way would be to use a piece of 5/4 (not 3/4!) PVC lumber ripped to fit between the Brick molding and the outside corner that's cut to length so it will be at least 1" above the top railing with a small piece of Z moulding at the top of it to keep water from getting in behind it.
PVC lumber can be painted to match the siding color.
I'd use my Kreg tool when installing the railings and use 3" long screws if drilled on the underside of the railing you would not see the screws.
I'd also replace that wooden brick moulding with PVC brick molding so it would not rot out at the bottom.
Old 08-08-17, 02:34 PM
G
It is not covered.....
Would you have pictures? I'm not understanding.
Old 08-08-17, 03:00 PM
XSleeper's Avatar
Received 675 Votes on 624 Posts
Can't see how your other post sits without a picture from farther away.
Old 08-08-17, 06:11 PM
G
I will cut them in however I want
Old 08-08-17, 06:30 PM
XSleeper's Avatar
Well then your post could be notched and bolted to the side of the rim joist. It will sit in front of the vinyl corner and it does not get attached to the house at all. You might just want to get your j channel and siding nailed on first because it might be a little hard to nail it if you wait to side it until after the railing is up.
Old 08-08-17, 06:46 PM
G
What about under the door?
Old 08-08-17, 06:52 PM
XSleeper's Avatar
Run a piece of your decking through a table saw so it fills the space between the deck and the sill nose. It should be as long as your door trim is wide. (Outside edge to outside edge)
