cut hole in aluminum siding for bathroom vent fan
Old 10-25-17, 10:12 AM
My house has aluminum siding. I want to install a bathroom vent fan that vents to the exterior of the house, straight through the wall. Once I cut the hole for the vent, what's the proper way to finish up the hole so the siding remains waterproof?
Old 10-25-17, 11:13 AM
Received 3,982 Upvotes on 3,574 Posts
A ceiling mount that vents out or a thru the wall mount ?
This is the wall mount that I use.
Comes as a complete kit with the outside hood and damper. The hood gets attached and weatherproofed to the siding.
Panasonic FV-08WQ1 - Whisper - Wall Mounted Fan
Old 10-25-17, 12:02 PM
Thanks for the reply! It will be on a wall, an exterior wall. Right above the shower, direct to the outside.
Old 10-25-17, 06:06 PM
XSleeper's Avatar
Received 1,920 Upvotes on 1,724 Posts
If possible I would pick a spot that is centered on a row of siding... so if you have 7" siding, for example, drill your hole 3 1/2" from the top or bottom edge of a row... so that when you install your vent you can just caulk around it without having to worry about the vent sitting over 2 different pieces of lap siding.
If you have no overhang (wide soffit) you would obviously need to use a vent fan that is louvered, or rain will get driven right into the fan.
Old 10-25-17, 08:02 PM
Yes.... sidewall venting can be an issue. One good thing about the Panasonic fan is it comes with a downwards pointing vent cap.
Old 10-25-17, 09:17 PM
ray2047's Avatar
How about a siding block?
Old 10-26-17, 05:53 AM
Received 128 Upvotes on 113 Posts
Just not a great plan.
What's above this area?
Is there a second story, or attic?
