Help with exterior basement coating
Image here
Hi! New homeowner here, need some help with some issues on our exterior. If you look at the image you'll see that the coating/insulation/covering on the outside of our basement walls has gotten torn up. I've tried a Google search, but, as you can maybe tell, I'm not really sure what terms to use to find what the fix should be. How/with what product do we fill these holes?
Any help is appreciated!
If you click on 'Image here', it should take you to the image on Imgur. On mobile, so could figure out if there was a way to put it in the post without linking to an external site.
That looks like stucco [parging] Basically you'd scrape off all the loose and apply another coat. The big box stores often sell premixed bags [just add water] of stucco mix although mortar mix would also work,
