replace just end of trim or whole piece (dry rot)?
Received 0 Votes
I have some places where trim around doors etc are rotted because snow has sat against the wood in the winter I would suspect?
One area the rot is only about 5 inches on a maybe 6 or 7 foot long piece of trim. I dug out the rot (very easily I must say) with a 5 in 1 tool and was thinking of sawing it off straight with maybe a jigsaw and then just getting a small section of trim the same size to nail in there and then caulking the joint of the 2 pieces.
Should I do this or replace the entire 7 foot section of trim?
Does it matter either way?
If you just replace a portion it's a good idea to prime the cut edge and then caulk the joint as you set the patch piece in place [so the caulking extends into the joint] Either way it's a good idea to prime the bottom edge of the molding before installation.
