Go Back  DoItYourself.com Community Forums > Exterior Improvement Center > Exterior Paneling and All Exterior Sidings
Reload this Page >
Top of Window rotted? How to patch while exterior wall is ope.
Old 10-25-18, 11:17 AM
B
My house had rot to the window header due to a gutter over flowing. The wood window has rot in the top part of the window (The head?). This window is a 12 foot, 4 mulled window and isn't within my budget to replace. What should I do to the top to seal or patch it. I have the siding off and trim off. I am about to put in a 2nd header in over the window as the first header has a small section of rot.
https://imgur.com/a/WUpaNyL
Old 10-25-18, 11:21 AM
XSleeper's Avatar
Received 675 Votes on 624 Posts
Not much you can do. It's an integral part of the window. Prevent it from getting wet again.
Old 10-25-18, 12:23 PM
pugsl's Avatar
Received 74 Votes on 67 Posts
I have repaired windows with fiber glass. I like the type like body filler. There also is some you use fiber glass cloth with it. Repaired a sill about 15 years ago and still going strong.
Old 10-25-18, 12:32 PM
Received 319 Votes on 283 Posts
If you do use a patching compound make sure you remove ALL the rotten wood first. Those types of repairs don't hold up well if there is any damp or non solid wood attached to the repair.
