Cypress siding fuzzies?
Old 04-18-19, 07:37 AM
R
I have recently power washed my cypress siding with too much pressure before i knew any better to do so. The wood has some pretty bad fuzzies now . A normal 80 grit pad on my orbital sander works for the high spots but it will not get down into the grain. Is there a specific pad that would help with this? Would there be an easier solution than having to sand the whole exterior of the house?
Old 04-18-19, 08:00 AM
P
Received 620 Votes on 573 Posts
Can you switch your sander to be circular and not have an orbital/random action? If so that should allow it to cut better and knock down more fuzzies and grain. You can also try a belt sander.
Old 04-18-19, 11:40 AM
Received 316 Votes on 280 Posts
What type of finish [if any] do you intend to apply to the siding? Normally the 'fuzz' from overaggressive washing is fairly easy to knock down with sandpaper.
