Go Back  DoItYourself.com Community Forums > Exterior Improvement Center > Exterior Paneling and All Exterior Sidings
Reload this Page >
Need thin (1/16") flat, rot-proof, shim/spacer material.
Old 05-13-19, 10:13 PM
Hello,
I'm trimming out my exterior windows with PVC and need to build out the trim about 1/16" to bring it flush with the face of the frame.
I haven't been able to find thin PVC or composite material to use for this purpose. I don't particularly like this idea, but am considering using asphalt shingle material as shim/spacer material. Is that a bad idea? Do you have a suggestion for an inexpensive material to use?
Thanks in advance.
Old 05-14-19, 12:03 AM
ray2047's Avatar
Received 13 Votes on 11 Posts
Try vinyl floor tiles. You can buy as little as a single one at Bigbox, Self stick tiles will even help keep it in position.
Old 05-14-19, 01:29 AM
Marq1's Avatar
Received 367 Votes on 342 Posts
Tar paper/underlayment/roofing felt was my first thought, shingles would be much thicker!
It doesn't actually have paper in it, a fiberglass mat so it will last a long time and comes in different weights/thickness!.
Old 05-14-19, 05:41 AM
XSleeper's Avatar
Received 667 Votes on 617 Posts
Table saw and pvc..........
Old 05-14-19, 06:25 AM
2
Received 46 Votes on 39 Posts
Scraps of laminate countertop material like Formica.
Old 05-14-19, 08:58 AM
Thanks.
Thank you @ray2047, @Marq1, @XSleeper, and @2john02458.
All great suggestions, and, potentially, differing thicknesses.
Much appreciated.
