Top row of siding falling off
Old 04-24-20, 09:09 AM
Received 3 Votes on 1 Post
The top row of siding is falling off on my garage. I try to snap it back but it will come off again. Any ideas on the proper way to fix this?
You can see on the attached pic it was nailed but came lose. Whats the best way to fix this?
Thank you!
Old 04-24-20, 10:06 AM
Received 157 Votes on 144 Posts
I cannot see the upper edge of the loose piece.
Was it crimped?
Also that nail up top could not of gone through itas the nail is there and the siding is down.
Old 04-24-20, 04:23 PM
XSleeper's Avatar
Received 679 Votes on 628 Posts
As Manden said, tabs weren't punched on the top edge to keep it in the finish trim. Or maybe they ripped it too narrow to punch it. The roofing nail through the finish trim is a nice touch.
Old 04-24-20, 04:31 PM
B
Received 88 Votes on 77 Posts
Go to a store that sells vinyl siding and tell them your issue. I think its called undersill trim and gets nailed to the wall with trim against soffit . The best I have seen requires you to press barbs into the top of the vinyl siding (requires purchase of the tool) such that barb catches on lip of the undersill trim when pushed up into place.
Old 04-24-20, 04:42 PM
XSleeper's Avatar
He has undersill trim (finish trim). Its in the picture.
Old 04-24-20, 05:14 PM
Received 77 Votes on 72 Posts
#1, Get rid of that roofing nail in the face of that trim.
#2, If that even is under sill that last piece of siding should have been punched with a snap lock punch with the hole facing out so the tab faced toward the outside.
Once that's done there's no way it would ever fall out again unless you used a zipper tool.
https://www.erniestools.com/tapco-sn...k-punch-11375/
Old 04-27-20, 06:52 AM
Thanks for the tips.
I think this is the process you are describing? https://www.youtube.com/watch?v=BJzl7MbY5OU
It looks like those punches were never made on mine.
I'm new to this so appreciate all the help!
Old 04-27-20, 07:51 AM
Do this on a warm day.
If it is to cold instead of creating tabs it will just punch them out.
Old 04-27-20, 10:13 AM
Thank you! I appreciate the help.
