Replacing Rotting house/deck trim with pvc. Nailer?
Old 05-25-20, 03:58 PM
L
I have several areas of my deck and house where the pine trim is rotting. The areas are prone to moisture (no sun, base of deck near ground, etc.). I live in the northeast so the seasons can be fairly extreme. Iím thinking that replacing these areas with pvc trim would make the most sense. Other similarly low maintenance/long lasting options? I realize pvc is more expensive.
Also, should I use a siding coil nailer or can I get by with an 18 gauge galvanized brad given the expansion/contraction?
Old 05-25-20, 04:02 PM
Received 77 Votes on 72 Posts
I use white head, trim head screws.
lpaul626 voted this post useful.
Old 05-25-20, 04:13 PM
XSleeper's Avatar
Received 679 Votes on 628 Posts
Composite deck screws work well. Set the heads just below the surface then fill.
Old 05-26-20, 05:20 AM
P
Received 638 Votes on 588 Posts
I too prefer screws. Nails of any type seem to work loose with the expansion & contraction. Also, don't go stingy on fasteners. PVC must be held flat against it's will on hot summer days. I've seen it pop the heads off nails when not enough were used. And more fasteners helps it better resist buckling on hot days.
