old school awning removal
Old 10-04-20, 07:48 PM
B
I have bought a 50 year old home that has original aluminum awnings over 2 windows. Does anyone have experience with removal of these awnings . Any advice would be appreciated . Thanks
Old 10-04-20, 07:50 PM
XSleeper's Avatar
Received 679 Votes on 628 Posts
You generally just disconnect the arms that are mounted partway down on the window, then there are screws on the header track that get removed.
Old 10-05-20, 04:26 AM
B
No arms on side
The awning does not have arms on the side but rather full side panel. Tried to download a picture but it wouldn’t download. I wondered if I simply removed screws at the bottom of awning on the inside of the awning might tilt up and off header bracket? I can see the screw along top of awning above the awning but they would be tough to get to because of projection distance from the house.
Old 10-05-20, 04:33 AM
B
Awning looks similar to this
[img]blob:https://www.doityourself.com/960c7785-9acc-4d8b-8873-392c19e25a07[/img]
Last edited by bams12; 10-05-20 at 04:34 AM. Reason: This copy and paste did not work
Old 10-05-20, 04:48 AM
Received 323 Votes on 287 Posts
link doesn't work
If the awning doesn't have arms/brackets it most likely has screws were the sides are bent in.
Old 10-05-20, 05:10 AM
XSleeper's Avatar
Regardless, you have screws midway down that keep the sides from spreading. If you can't see the screws on top above the awning, then the awning clips into the header track. You just lift the awning, hinging it upward and then pull it out of the track. Once the awning is removed, you remove the screws in the header track.
