Cutting last siding plank under sloped roof
Old 10-07-21, 11:49 AM
E
Hello
Im residing garage with LP Smartside. Garage has sloped roof and I wonder if the way I'm going to cut and nail the last row is accurate. Here is what I have now.
One board + cut board to span the whole wall lenght
Next I'm thinking that I'm taking a new board (red) cut it to size with 1 in overlap with the existing board (brown). The height of the right end will be 1 inch.
Similar case with the very last row (green).
Am I correct that the right end of red and green boards will just hang there without anything butted against them?
Old 10-07-21, 04:11 PM
XSleeper's Avatar
Received 1,921 Upvotes on 1,725 Posts
You need to face nail the ends. Nail it where it is still about 1 1/2" tall so that it doesn't explode. Your pieces should not be square on the end they should come to a point like a triangle. If you have a piece that is short... You need at least 2 nails in it to hold it.
Old 10-07-21, 04:42 PM
E
Thank you very much with the advice about the triangle point!
