I noticed a crack in the window sil/stool, with one end coming up. Material looks to be PVC. Most of the repairs seem to focus on wood rot, but I wasn't able to find much information on how to correctly perform this repair on cracked PVC in this location. I was initially thinking some sort of PVC filler/glue, but wasn't sure how this would hold up with changing temperatures. Would appreciate any advice/thoughts. Pictures below:
That sill nose looks to be a replaceable piece... it's just shot onto the front of the sill. I would just pry it off and fasten a new piece on. Either wood or pvc.
@XSLeeper. Thanks for the quick reply and for the clarification - sill nose was the term I was looking for! Is there a particular reason you would suggest taking it off and fastening a new piece on rather than fixating it (in some way) and/or filling in the gap? The sill nose looks to be one long piece spanning 4 windows, and the break is in the middle.
The break will open and close with the seasons. PVC expands and contracts a lot, more so when painted a dark color. If you don't want to replace it, push it down and nail the left side, then caulk the crack and the top and bottom edges with OSI Quad. It will stick the best to pvc.
Redoing the siding (vinyl) and flashing after a new shingle install.
With a profile like this how does one overlap at the peak so that it isn't just relying on a bead of sealant where the two butt up against each other.
Having a hard time wrapping my head around it due to the angles.
I tried to get some overlap but then ended up with the line being angled instead of straight.
[img]https://cimg7.ibsrv.net/gimg/www.doityourselft.com-vbulletin/2000x1504/gablepeakfascia_0960f6e9bfd3930d4b00cddc4100fcc04ef9417a.jpg[/img]
(ignore the gap in the dripedge - whole other deal)
Read More
My Vinyl siding corner piece came and lose.. the piece is close to the electric al lines and I'm not sure how to handle this. Also I was planning on cutting the nail ing flannel off and glueing back up. Finding it impossible to find someone to fix.
[img]https://cimg2.ibsrv.net/gimg/www.doityourselft.com-vbulletin/860x1158/img_20211215_100637639_hdr_2_036346538172fc6cd537d0144ebe1ec6f0202c63.jpg[/img]
Any suggestions ideas or pointers will be greatly appreciated
thank youRead More
