Siding Corners
Old 02-12-22, 05:13 PM
Siding Corners
Hello, I need to replace some of my aluminum siding corners that have come off. The issue is that I can't find them anywhere in the size I need which is 10" long and can accomodate 3/4" wood siding.
I found some that were 10" long, but the grooves on the bottom wouldn't fit the thickness of the siding. It's hard to believe these are so hard to find! Is there an alternative that I can do to keep the water out?
Thanks!
Old 02-12-22, 05:53 PM
XSleeper's Avatar
Received 1,923 Upvotes on 1,727 Posts
If you go to a real lumber yard, (not a box store) they should have them. If not, here is one source.
Primed Smooth Outside Corner for 3/4 x 10 siding | Pro Siding Accessories
jsprague voted this post useful.
Old 02-12-22, 06:15 PM
Thanks so much! It looks like our local lumber yard does have these and if not, it looks like you found exactly what I need online. Much appreciated!
