Remodeling a recently purchased cottage...
Old 06-04-22, 05:05 PM
B
Hey folks, What can you suggest to fix this? Thank you
Old 06-04-22, 07:04 PM
Tolyn Ironhand's Avatar
Received 595 Votes on 511 Posts
Personally, I would remove the electrical service, that thing is a mess. Then repair the siding and holes in the building. Then install a new service and mast.
Old 06-05-22, 05:01 AM
P
Received 1,564 Votes on 1,406 Posts
That was a bad siding job. I usually unbolt the weatherhead and conduit so I can slide trim stock behind. Then install the vinyl siding J channel.
Old 06-05-22, 09:36 AM
B
Pilot Dane- Alot of hack jobs on this place prior. It's a work in progressbfor this guy. Trying to keep it as cheap as possible. 10 years max it's a demo. Thanks for you advice 👍
Old 06-05-22, 09:42 AM
B
Tolyn Ironhando thank you for your advice. What kind of money are we talking to get the work you mentioned done approximately?
Old 06-05-22, 06:27 PM
It varies greatly depending on your area and everything involved. You are in Canada so I couldn't even venture a guess. If you DIY it you are looking at about $600 in the material. If that is not an option I recommend getting some local electrical contractors (3) to give you some prices.
