how to attach a camera to my vinyl siding
We just had brand new vinyl siding put on the house. I want to attach a ring camera on it by the front door. It came with two screws. I am wondering what the proper way to attach something to vinyl siding. What material is it under the siding? What kind of screws? how long do the screws need to be? the photo below is what came with the camera. It is a small ring camera
Usually I throw away the provided hardware. While convenient it is usually pretty poor quality and prone to rusting.
For something lightweight I use short stainless steel screws. They only penetrate the vinyl siding. This has the benefit of not putting holes in the backer membrane (house wrap) and the siding is free to move as it expands and contracts. For something heavier I use stainless steel or quality deck screws (for their corrosion resistance) and screw through the siding into the sheeting behind, so anything 2" or longer.
I think the short answer is you don't.
Remember anything you screw into the siding will leave holes long after the camera has quit working or become obsolete. First suggestion is to see if you can find a different surface to mount it too.
Second, if there is nothing else then a thin piece of plywood on the back side will give you something much more secure to attach to than the soffit material itself, especially if there is a little mass involved.
Norm201
voted this post useful.
Wherever you put it will leave holes. That's just the way it is.
The camera is light. Short stainless steel screws into just the siding would probably be enough.
A sharp screw will start its own hole into the vinyl.
XSleeper
For anyone who doesn't know, the Ring camera is a very small, light combination doorbell/camera. It does not attach to the "soffit".
What kind of answer is that ?
vinyl doesn't repair well.
Either way, not really an issue since Janebench wants to put it on the siding.
These work well: Siding Clips
I don't have any Ring cameras so unsure how they mount but if there isn't a screw hole that works well with the clips, I often use metal junction box covers. Easily available and cheap if you don't have some scrap already handy. So this would be used as an adapter to go from the camera mount to the siding clip.
