Bezel for hole in vinyl siding
Old 09-30-22, 02:44 PM
W
I am installing a split-mini AC/Heat pump for my garage shop. I have to put a 2-1/2" hole through the wall that has siding on the outside. Is there a bezel or strip I can use to help hide the hole in the vinyl siding? Or just fill up the gap with calking?
Old 09-30-22, 03:18 PM
XSleeper's Avatar
Received 1,574 Likes on 1,411 Posts
Most times I see AC lines drilled right through the siding. You "could" install a 6" mastermount and drill the hole in the cover. Either way, it's still a hole. Drill the hole the same size as your pipe wrap is.
Old 09-30-22, 03:29 PM
I always see the hole cut fairly close to the right size and then caulking around the tubing insulation.
Old 10-01-22, 06:21 AM
P
Received 1,628 Likes on 1,461 Posts
If you want to dress it up you can use many siding tricks. Run the hole through a sheet of trim stock that is trimmed out with J channel. You can also use any escutcheon or base intended for light fixtures, outlets or spigots.
Old 10-11-22, 09:43 AM
K
Here is how I did mine for a dual zone unit if it helps prompt some ideas for you. Mounting block with schedule 40 pvc sleeve (may need painted at some point depending on uv degradation).
