Hi All, has anyone ever installed vinyl siding on a 2X7 shed door, looking for tips on how this would work, I was thinking about J all around, and a starter strip on the bottom.
I All , I scraped the siding issue and built new doors,, problem now is the doors are on the same plane as the front of the shed walls, when I install the J up against the hinges the doors wont fully open, I think I know the answer but looking for other thoughts.
You need to trim the doors with a 1x4 or similar, and mount the hinges on that. You'll also probably want to have a ledger and threshold of some type on bottom... because the doors will be out beyond the edge of your floor.
If you're going to have a brake there to bend and cover any trim, you "could" remove the doors and bend some aluminum trim coil to cover the perimeter of the door opening. Bend an L shaped piece about 1 1/2 x 3. Then mount the hinges on top of that... then j channel around the hinges.
Hello Everyone,
What siding is this and where can I pick it up. Is it just fiber cement stucco siding? But I am sure there are many different kinds? Thanks!!
[img]https://cimg7.ibsrv.net/gimg/www.doityourselft.com-vbulletin/2000x1504/img_9112_8cee84cb5b3f4ac056e5a67b0c63a766ad6b708c.jpg[/img]Read More
Getting my 60's ranch exterior redone with wrap, insulation and vinyl siding. Removing older masonite. I saw a house with a nice cedar shingle style on the front and traditional shiplap on the rest of the house. At $400 extra per sq, I can't afford the whole 20 sq sided. What do you think of just the front done, same color?Read More
