Starter Relay
Starter Relay
Need to know the location of the starter relay on a 4630 Ford Diesel Tractor.
I think that, if you follow the positive battery cable, it will lead you to the solenoid. There should also be a heavy cable from the solenoid to the starter and a couple of smaller wires on the solenoid which actuate it.
The RELAY, if that is what you are looking for, may be just forward of the firewall, near the switch. The solenoid is a relay, also, so we may need more information. Are you having problems with it starting? What are the symptoms?
Previous Thread
Next Thread
