Painting over faux finish
Received 0 Votes
I painted 2 of my four walls with a darker strie over a light base. And it is TOO dark. I kept thinking it was going to lighten up when it dried, but it didn't. I think we want to try it vice versa but what do I need to do to the walls I already strie'd to get them ready to try again? Sand, spackle, paint kilz and try again? Help.
paint always dries DARKER than what it looks like wet.
i would just paint over what you've got with the darker color & strie the lighter color over it. i don't see the need to sand or spackle or anything. but maybe you should try your plan on test area first.
Received 0 Votes
Stripe mistake
Why don't you just paint primer over it and start over again? Not sure why you'd need to sand and spackle and stuff if it's just paint. You could try just painting over it like Annette suggested, but if it's a real dark color, it might show through some. If you prime it that should block enough of the previous color that it won't interfere with what you are doing.
