Stenciling with oil base paint
Old 01-05-07, 03:19 PM
I want to stencil with oil base stencil paint. If I do, will I have to prime the walls with oil primer the next time I paint?
Thanks
Old 01-05-07, 06:51 PM
K
You will probably have to spot prime if you use oils--but why do you want to use oils for stenciling? There are many acrylics which will give you similar if not identical colors/richness.
