DO I need a protective coating over Oil based Glaze?
Old 01-08-09, 05:40 AM
V
We simply cannot afford replacement, SO, I have glazed my thermofoil cabinets. I realize this is not a long term solution, but it will buy me time until I can replace 53 cabinet doors and drawers.
1) I used "No sand" to degloss my doors, then,
2) I used 1qt each of Benjamin Moore's alkyd glaze and satin impervo paint. Honestly, they look good. (If I would to do this again, I feel like SW has a LITTLE bit better adhesion. I tried both, but BM was smoother and easier to apply.)
Since I did not prime, paint, and then glaze , would anybody recommend a protective coating over the glaze? Polyurethane?
Old 01-20-09, 04:12 PM
L
Without proper prep including priming I would be more concerned that it will not stick rather than being worried about washing off the glaze. I have found that proper preparation takes more time than finishing a project but always worth it. IMHO
Old 01-27-09, 03:02 PM
D
Thumbs up
Yeah I would suggest a polyurethane for you to use as a protective coating, you should be sure to use one, well at least I always do. Beer 4U2
Old 01-30-09, 05:51 AM
A
painting
I have never used one and haven't seen a problem. I guess it depends on how much traffic and potential bumps you'll get on those walls.
Old 02-28-09, 07:19 AM
B
Yes, always protect your work, plus it will give the glaze job some depth. Two coats of satin would do it, spraying would be best.
Billy
