Tissue Paper wall finish
Old 04-06-09, 11:21 AM
V
Question Tissue Paper wall finish
When finishing bathroom walls with the tissue paper technique, is it necessary to seal the finished walls with anything to prevent water/steam from causing it to peel?
Old 04-06-09, 11:58 AM
B
Absolutely! It is imperative to seal your artwork, plus it adds a degree of depth. When marbleizing, I seal after each application of technique. By the time I'm done the "marble" looks an inch deep.
Bill
Old 04-06-09, 06:48 PM
Q
Another suggestion is to apply a layer of your base paint on the wall and while wet, apply your tissue paper. To smooth out slightly just go back and roll again with your base paint. You're done. No need for another step.
If you want to add a glazing technique, be sure to use a good quality glaze so no sealing will be necessary.
We have used Bella Fresco for years and feel that it is one of the very best on the market. It may be a tad pricer that what you may find a big box store, but there is NO comparision in quality, durability or results.
Also be sure to tear off most of the finished edges of your tissue as you only need those for the edges of the walls. And be sure to get enough of the very same tissue paper to complete your project.
Hope this helps.......
Last edited by Shadeladie; 05-10-09 at 08:29 AM. Reason: Link removed. Advertising not allowed.
Old 09-07-11, 05:33 AM
The tissue paper faux finish is a great finish to do if you have walls with slight imperfections. Apply one coat of primer to the wall. This can be any color that you pick for your room. You don't need to paste the tissue, roll you paint on and press the tissue into that, then re-roll over the tissue. Practice technique first before committing.
