Master Bedroom & Bath paint
Old 02-05-11, 01:17 PM
I have finally decided to cover up the stencils (what is the stuff usually put on with - oil based or acrylic paint?? - I have to get Killz.) in MB & MB. I picked out Sherwin Williams Metallic Impressions. Figured on Brushed Metallic with 3 walls Kilim Beige Metallic and the wall opposite the door with the headboard on it in Brushed Metallic Turkish Coffee Metallic. basically light beige and a purplish-gray. It's a med-lg room.
Question: Should I do all 4 walls brushed metallic or go cheaper with just doing the accent wall? Do I match the M. Bathroom with an accent wall also or just go the beige color?
Old 02-06-11, 03:40 AM
Received 319 Votes on 283 Posts
I'd start with one wall to see how you like it, that will give you an idea of how well it looks and whether or not more of it will look good or be overwhelming.
Old 02-07-11, 07:17 AM
Received 94 Votes on 83 Posts
I'm not sure I'd want a metallic finish in a bedroom, I'd definitely start with one wall and live with it for a little while
Old 02-13-11, 07:11 PM
D
Definitely use a base coat first. That will help cover up stencils and make your finish coat go on smoother. Try one wall first, usually the largest.. The bathroom need not match, but might be a nice touch.
