Sealing plywood joints
Old 04-24-13, 08:59 AM
K
In a related post earlier, I wanted to paint plywood wall panels to get the semi-smooth look of drywall. Does anyone recommend a product to seal the plywood joints so as to resist cracking when there is movement?
Old 04-24-13, 09:19 AM
Received 398 Votes on 354 Posts
About all you can do is use caulking and smooth it off with a putty knife. Personally I'm not that fond of trying to get plywood look like drywall although I have done it before. Any particular reason you aren't using drywall?
Old 04-25-13, 09:11 AM
K
I need to bring the shear load up to specs,
Old 04-25-13, 09:25 AM
Received 98 Votes on 86 Posts
You could try to mud and tape as if it were drywall. I think I might go with mesh tape and setting compound in this case, probably would look for some kind of adhesive to apply to the plywood before putting the tape on as well.
Old 04-25-13, 09:29 AM
I'd laminate the plywood with 1/4" drywall like was suggested in one of your other threads.
