vinyl fence repair
Old 06-02-04, 06:50 AM
rickarchitect's Avatar
vinyl fence repair
I want to adjust my existing vinyl fence to follow the slope of my side yard. I can easily detach the panels and reset each one at the lower distance that I need but if I do that there will be holes from the existing brackets. Is there some type of hole repair that you can use to fill in the screw holes?
thanks
rj
Old 06-02-04, 09:48 PM
L
You could simply put screws in the holes with the screw heads painted to match the vinyl, of you could find some plastic buttons the same color as the fence and bore a large enough hole to snap the buttons into. The patio covers I build use a 5/8" button where we have to drill a hole in a post wrap to attach the wrap to a post and beam. Check with a vinyl fence supplier -- they may have something similar.
