Vinyl fence
Vinyl fence
I am planning to install vinyl fence (privacy). I need suggestions on which brand is considered to be good and from where should I shop. One option I was considering was Certainteed.
Thanks
Thanks
Not all vinyl is created equal!
I would start at a local supplier of vinyl fencing materials. Look in the Yellow Pages. They will gladly give you scraps of their product so you can compare it to other mfgrs. and sources. Take a Sharpie and write on the scraps where each came from. The 2 biggest things you need to look at are wall thickness and UV inhibitors.
