Chain link fence - set posts in concrete or not
Received 0 Votes
I live in Iowa and the ground freezes and thaws. Most fence posts are set in concrete, but I've seen some that aren't. Those seem to be driven into the ground a good 3-4 feet. Would a fence be stable without the concrete? What would the pros and cons either way?
Thanks!
jdubb
Thanks!
jdubb
Much depends on the soil around it that prevent the posts from leaning.
A skinny steel post will tip easily in many soils. Setting the post in concrete increases the lateral reisitance many times.
you can always forget about the concrete if you have a long enoght post and a lot of energy.
Dick
Dick
Received 0 Votes
The ground has a lot of clay and it was tough to dig deck holes with a 2 man auger. My immediate neighbors didn't use concrete, but they are not on a hill. On one side of the yard it begins to slope down and the fence will be on that part. I'm concerned it may lean over time. You vote concrete?
We have youth laborers in the family and either way, they'll either have to dig the holes or drive in the posts.
jdubb
jdubb
Received 0 Votes
same question
I was wondering the same thing. I have almost the exact situation, and I was worning what you ended up doing? I was thinking about putting the end posts in concrete and the line posts just pounded into the ground.
Received 0 Votes
A steel post has the same diameter top to bottom. If you set it in soil , it's GONNA lean over time. Set it in concrete. Dig the hole like a bell -- wider at the bottom than it is at the top. Just make sure that the bottom of hole is below your frost line. Then you will have no problems with the post ever leaning or rising.
They do away with concrete.
They also will lean because of the area in contact with the soil.
It is just a question of how high or low your standards are.
Dick
Dick
