Post A is good. Where does Post B go?
Old 06-09-07, 11:07 AM
Hello. First time fence builder.
I know where my first corner's post can go, but I'm not sure where to put the opposite end's post (I don't have enough reference points). That is, how do I know I am still on the plane of my lot line? Two posts make a straight line no matter where you sink them.
I'd have no problem hiring a surveyor to come out, but only if he can spray paint some spots for me. Anyone know if that's part of the package?
Old 06-09-07, 12:35 PM
nap's Avatar
nap
nap is offline
New Member
Received 2 Upvotes on 2 Posts
if you have straight lot lines, corner pins from the surveyor would be adequate to line up your fence. Drawing a string (if not a large lot) or using a transit to site the line would allow you to place the posts correctly.
If you have curved lines, the surveyor should place pins that allow defining that curve.
As with all things, ask the surveyor when you call them.
Old 06-09-07, 12:48 PM
Thanks. We have a straight 40'x120' city lot. I'll keep looking for the property markers (I could only find one.).
Old 06-09-07, 01:40 PM
Received 786 Upvotes on 689 Posts
If you have or can borrow a metal detector it will aid you in finding the survey stakes. Often they are just a length of rebar sunk in the ground at the correct location. The newer ones [around here] have a plastic cap on them with the surveyor's license #
Old 06-11-07, 01:14 PM
W
Received 61 Upvotes on 53 Posts
Fence
You need to find the permanent corner markers. Otherwise, your fence could end up being built on your neighbor's property.
Old 07-22-07, 08:58 PM
With all these fence placement questions, doesn't any body ever just talk to their neighbor any more?
I'd just read my deed, look at the survey you've got from buying the place, then any others that are on record and the check with the platt book. Last thing I'd go to the neighbor and see what they have to say. If they agree with what I thought was right then I'd mark it out and ask if they have any problem with it.
99 times out of a hundred they don't know any better than you do if that much and it's going to cost them the cost of a survey if they don't like it later. They'd never get that moved in court if they've agreed to it when it was built.
Old 07-22-07, 09:32 PM
HotxxxxxxxOKC's Avatar
I would not go to the neighbor. The neighbors could move and the new owners could have the fence taken down.
