Using existing metal post fro PVC fencing
Old 07-29-07, 07:12 PM
D
Unhappy Using existing metal post fro PVC fencing
Hello,
Can anyone share your thoughts on th follwing: I want to remove our chainlink fencing and replace it with PVC. Can we eliminate the extra work of cutiing the metal posts and keep them foe the PVC fencing. Most are spaced about 6' apart. I guess is a matter of spacing the PVC post sleeve in the right plae and pouring cement. Would this complicate the whole project?
thanks
Old 07-29-07, 07:32 PM
czizzi's Avatar
I think that you should install the fence per manufacturer recommendations, not what would seem to be the easiest and quickest. The fence should last for years, and that is what you will get by following the directions that come along with the fence. The end result will look like a professional installation and not something thrown together with duct tape and some string. You may also void any warantees if you vary from the recommended installation methods.
