Anchoring gate post on concrete
Old 10-10-07, 11:22 AM
We are putting a 5' high dog run at the house we just bought. I have all the posts, chain link, etc. and have done this before on grass. This one, however, will have a 4' gate on the concrete patio slab. My wife doesn't want the gate in the grass so we won't have to leave the concrete to get from one side of the patio to the other.
I think I can put the hinge post off the patio, but how can I anchor the latch post? I haven't been able to find anything to anchor it and hate to try punching a hole in the concrete.
Old 10-10-07, 03:58 PM
Try going to a fence store to see if the make a flange that can be attacked to the bottom or a welding shop that can make you one and weld the pole to it. Then anchor the flange with lag bolts or wedge bolts. The other option is to see if you can rent a core drill with a masony core bit. They come in different sizes. Core drill out the concrete, remove dirt to the depth you need, refill the hole with concrete, plumb the pole at the desired depth and distance for the latches to work.
Old 10-10-07, 04:07 PM
I'll see about the core drill as that seems the best solution. I was told that the fence posts were too light to weld properly. I got them from Lowe's.
Old 10-11-07, 09:55 AM
Somewhere, someone must have a reasonably priced bracket that could be Tapcon screwed to the concrete and the fence post slipped either over or in it. So far I haven't found it.
Old 10-11-07, 11:12 AM
the_tow_guy's Avatar
Received 55 Votes on 45 Posts
I would think you could use a pipe flange anchored to the slab and iron pipe for the post like what's here:
http://architecturaliron.com/piperailindex.htm
or here:
http://www.afence.com/handrail_.htm
http://www.juliusblum.com/prodsec03.html
And here's an interesting page with a how-to:
http://www.instructables.com/id/How-...mple-Handrail/
Here's the flange they used:
http://www.simplifiedbuilding.com/pr...roducts_id=270
Old 10-11-07, 05:21 PM
Thumbs up
I bought my fence from a fencing store , Heavier gauge. I also had the make a 2 "T"clothes line poles that have been welded in the ground for at least 10 years.Those stores might sell fence at 12 1/2 gauge my fence is 9 gauge. Check with a fencing dealer if you want the flange method.
Old 10-11-07, 05:29 PM
See if the fencing store has it in galvanized flanged not iron.
Old 10-12-07, 12:01 PM
W
Received 19 Votes on 18 Posts
Flanges
If a flange is used, holes must be drilled to secure the flange to the concrete. Why not drill and remove enough concrete to set the post in concrete? Would be much more secure than using a flange. Good luck with your project.
Old 10-12-07, 12:30 PM
You're right. but rental on a core drill & bit is $150 and i just have to drill one hole.
Old 10-13-07, 06:20 AM
W
Hole
Is a core drill really necessary? Could you drill a series of smaller holes with a masonry bit and hammer drill? Just a thought. I always look for the cheapest route first. Good luck with your project.
Old 10-13-07, 07:23 AM
I might be home free, and I do mean free. My son has a contractor friend with all the drills I need and even offered to do the drilling.
