Installing chain link fence
Old 02-10-08, 04:53 PM
T
I want to install a chain link fence from my house to a detached garage, but I do not want to have to break up the concrete to set the posts. Is there anyway to attach the posts to the concrete without having to break up the concrete and repour it.
Old 02-14-08, 07:39 PM
L
Received 1 Upvote on 1 Post
tjsmith19,
Welcome to DoItYourself.com and the fence forum.
How long is the run??
You may be able to find a local welder who can make you posts with a flange on the bottom that can be red-headed to the existing slab. That would work in a fairly short run (20 or 30 feet), as long as there are no gates involved.
Old 02-15-08, 05:52 AM
T
It is only about 13 feet across, but I do want to put in a gate.
Old 02-15-08, 12:15 PM
W
Received 66 Upvotes on 57 Posts
Fence
What size gate?
You will need a hole at least 2 feet deep to anchor the gate post.
Look for a contractor to cut the holes with a concrete hole saw.
Old 02-15-08, 04:07 PM
L
Like wirepuller38 said, having a gate means you need footings at least for the 2 gate posts. A concrete cutting contractor can core drill the holes or you can go to a rental yard like United Rental or whatever's close and rent the drill and the bit to core drill the holes. Might as well drill them all -- you're only looking at 3 or 4 holes, depending on where you locate the gate.
Old 02-22-08, 11:54 AM
E
Originally Posted by Wirepuller38
What size gate?
We do alot of inside jobs and basement storage lockers and we always use posts on plates with anchor bolts. They are usually 8 plus 1 and have never had a single problem with them holding. We even do 30ft cantalever gates with anchor bolts on inside jobs and have no problems with them. I think 13 ft run will be no problem.
Old 02-25-08, 08:59 AM
Anchor Bolts
We used to anchor our heavier machines with redheads and other anchors but found they eventually worked out. We finally solved our problem with threaded rod anchored in epoxy. I believe that this is the strongest anchor available.
Jim
