Temporarily Remove Fence Post
Old 02-25-08, 02:51 PM
G
Hi all...
We have a fenced back yard (alternating board) and I want to build an 8X10 shed. The area the shed is going to occupy is 11X11, bordered by the fence on two sides and the house on the third.
I want to build the shed outside of the yard then move it into position Egyptian-style on pvc pipes. In order for this to be feasible, I need to remove a post and 2 sections of fence. Is there anyway to do this without digging out the old post... can a cut post be "mended"?
Your thoughts and comments are most welcome,
Rick
Old 02-26-08, 05:41 AM
W
Received 66 Upvotes on 57 Posts
Posts
Removing the post completely is the best way. A cut post cannot be reliably repaired.
Consider building the shed in place. Start in a corner of the space with the floor and 2 walls opposite the corner. Then move the structure to the opposite corner of the space to build other 2 walls. Then move to permanent location and install the roof. Build the walls as panels on the floor and stand up into place.
Do you have set-back requirements when locating a building near property lines?
Good luck with your project.
Old 02-27-08, 07:10 PM
L
Received 1 Upvote on 1 Post
I'd build it in place as well, as Wirepuller38 suggested.
He's questioning property line set backs -- I questioning any requirements for seperation from the house to the shed.
Requirements vary GREATLY from one place to the next. Where I'm at, I could build the shed without a permit -- it's less than 120 sq. ft. I could build it pretty much on the property line, as long as the roof didn't overhang into the neighbor's property. BUT I would need 6 feet of seperation between the house and the shed.
Check BEFORE you build!!
As far as the post -- remove it, assuming that you can put the shed in the spot you are talking about. Once the shed is done, install a new post.
