Removing a section of vinyl fence
Old 11-08-08, 01:25 PM
T
Need to remove a section of vinyl fence, since the gate is not big enough to allow a truck through...
Looking to remove the section/post nearest/adjacent to the gate...
but there is no visible hardware to remove (besides hinges)...
any advice?
Old 11-09-08, 11:35 AM
W
Received 19 Votes on 18 Posts
Fence
This may not be your brand, but it looks like a typical example:
Savannah/Pembroke/Woodgrain Privacy Fence Installation - Vinyl Fencing - Horse Fence & Privacy Fence - USA Vinyl Fence Company
Hope this helps.
Old 11-17-08, 08:04 PM
P
Temporarily Suspended
I've installed a lot of them. The top and bottom horizontal rails snap into the posts. The main problem would be that the cement at the bottom of the posts will prevent the posts from moving, so you can't slide the rails. It's hard to remove the rails even if you can move the posts.
I would cut the rails with a sawsall or a circle saw, if you can get it close enough, as close as possible to the posts. Then use L brackets to reinstall the section.
