dirt against wood fence
Hi all. Part of my yard slopes down in the back, which has a wood fence on the border. I want to make the yard a little more level. To do so, I would have to add dirt about a foot up on the fence.
My question is, what's the best way to protect the fence from the moisture of the dirt? I want to take up as little room as possible. Would plastic sheeting be good enough? If so, what mil would you recommend.
Thanks for the help.
I agree w/ airman! How long is it?? Are they pickets or is it a privacy fence? If you put dirt up against plastic even, it will aid in a fast deterioration of the posts/pickets. GOOD LUCK
The fence is about 80' long. There is a steep downslope to a creek behind the fence and I don't want to replace it if I have to.
I just might end up putting a small retaining wall by the fence and leaving a gap.
The fence has another 10 plus years left and I'd hate to replace it now.
Thanks.
Thanks.
Also, I'm sure you've already thought about this...but make sure any re-grading isn't going to impact drainage.
