Best / most economical fence that could support 1000 lbs
Hello, I am in Florida and have a screened patio. I wish to cover the outside of the patio with a fence that would keep all creatures from able to enter, to keep the cat safe.I figure the heaviest animal would be an alligator climbing the fence, at 1000 lbs. I was thinking of using 2x4 woven wire fence, 12.5 gauge, and I can attach it directly to the metal framing of the patio. The product did not mention anything about high-tensile, etc. Would this type of fence be able to support a 1000 lb creature trying to climb up it? Any other suggestions?
Building a fence strong enough to support the gator just means he might be able to get in. Shifting your focus to a fence a gator is unlikely to climb, like vertical pickets, might be more secure. A chain link fence is providing a perfect foot hold for those critters.
Bud
Bud
Norm201
voted this post useful.
Hmm,... there is always a new question that perks the best response... An alligator climbing a fence was a video worth tuning in to see... And yeah... Never knew they can climb a fence but now I do... so I have to keep that in mind when giving advice on installing fencing in Florida...
So... In the answer, the answer is a no brainer, but definitely not economical.. Aluminum fencing.. It no longer would need to be something to support a 1000 lb animal because its highly unlikely an alligator will climb vertical pickets with no rungs of a ladder to help him up. If it were a 6 foot high fence you would have a top rail at the very top or about 6 inches from the top and 2 bottom rails at the very bottom.
Aluminum fences come in two different wall thicknesses... and several lines come in different picket thicknesses... Much of the strength comes from the spacing between posts... either 6 feet or 8 feet center post to center post... And you could get a design that has the pickets come to a spike at the top preventing pretty much anything from climbing without getting hurt while going over the top...
You could go with the aluminum or you could go with a solid wood fence... Again, adding strength to the fence by assuring the fence posts are not too far apart from one another... A wood fence would be less expensive, but it would not last as long... So if you are planning to be in the home for 10 years a wood fence is fine.. 20 years & you might consider the more expensive option... 30 or more years and you are bound by knowing that a wood fence would never be secure past its typical 15 year life span.... If you did feel wood looks best for your surroundings, I would suggest using wood attached to steel posts. Steel posts being set in concrete. The posts would last 40 plus years and the wood materials would be able to be changed out time and time again using pretty much all the same brackets, lag bolts and bandings. Wood fencing , assuming you have the good side facing outwards would also give you a lot more privacy than any aluminum , iron or chain link fencing... And being you said this was for a pool area, privacy may be desirable.
I hope those ideas were helpful.... & good luck with those Alligators!.... Florida might be beautiful around this time of year, but I rather the northern snowstorms than sunny , warm and alligators greeting me in my backyard...
Norm201
There are a lot of videos on youtube, heres a recent one !
https://www.youtube.com/watch?v=z7DMjQJD7vM
Prove me wrong, but I have never heard of an alligator climbing a fence!
Just before I moved from fla there was a pic on the news of an alligator climbing a 4' chainlink fence.
2x4 fencing isn't a stout as chain link although even if the gator busted some of the welds I don't think a gator could get thru.
btw - welcome to the forums!
Put up a normal fence.
Put a 10,000 volt electric livestock line along the outer perimeter.
Should deter EVERYTHING from climbing the fence.
But a Bigfoot (Yeti) can weigh well over 1000 lbs you know... And the 10000 volts will just make him mad.
