Waterproofing a fence joint
Old 03-25-20, 05:56 PM
W
I am putting in a fence with 4x4s and I cut into them a c-shaped "joint" to put in my horizontal 2x4s.
So, would you put anything into the space to prevent moisture such as asphalt or caulking?
Thanks
Old 03-25-20, 06:00 PM
XSleeper's Avatar
Received 903 Votes on 829 Posts
If you cut or notch a treated post you should always brush something on the cuts. CopperCote or Anchorseal 2 are the ones I have used.
Fences typically do not get notched as it weakens the posts.
