Wooden gate disintegrating around metal latch
Old 05-07-20, 03:58 PM
RocketJSquirrel's Avatar
Received 18 Votes on 16 Posts
This gate and latch are only 8 years old, but the wood around the latch pin is disintegrating. There is no automatic closer on this gate, so it doesn't get slammed around too much.
I have tried holding it together with wood fillers (e.g., Plastic Wood) and staples, but it's still coming apart. Any ideas how to fix it so it lasts some more years?
One photo shows the latch in place, the other shows it unscrewed so you can see what's under it.
Old 05-07-20, 04:06 PM
Received 98 Votes on 86 Posts
Cut out the rotting piece and replace it with new wood.
joecaption voted this post useful.
Old 05-07-20, 04:22 PM
P
Received 914 Votes on 841 Posts
I really do not like modern pressure treated lumber. It just doesn't last as long as the old CCA. If you are anywhere near a coast check lumber yards, not home centers to see if they have 2"x lumber that is treated for ground contact. It will contain more preservative and might last longer than the commonly available above ground treated lumber.
Old 05-08-20, 05:37 AM
Received 104 Votes on 91 Posts
I agree, it needs to be replaced.
Next time use carrage bolts with a nut and washer on the back side, not lags.
Old 05-08-20, 07:03 AM
W
Received 34 Votes on 31 Posts
It looks to me like that board was bad from the start, judging from the way the grain runs at the end. Replace the entire board.
Old 05-08-20, 10:54 AM
Thanks for the replies. I know nothing about gate construction. What is holding that one board to the rest of the gate? I don't see any other hardware, is the board glued in or simply pressure-fitted?
PS, the really rusty looking metal frames are the originals, predating my ownership. The fence builders just reused them. Are there maybe hidden screws running through the metal to hold the now-rotting board in place?
Old 05-08-20, 11:13 AM
P
I'm certain it's nailed or screwed in place.
Old 05-08-20, 12:02 PM
R
Received 44 Votes on 35 Posts
I think you need to hire a local handyman to look it over and repair it properly.
Old 05-21-20, 03:18 PM
Unfortunately, the board is indeed nailed into place. I found the holes and got all excited thinking it was screwed. Then I could have just pulled out the wood and flipped it around and used the other end for the latch. But the board is held in place with 2 countersunk nails, 1 at each end, so I don't see any way to remove it. Dang.
Old 05-21-20, 08:07 PM
That's why they invented sawzalls and oscillating tools.
